Results 1 to 2 of 2
  1. #1
    Default HURTH ZF63A Transmission Removal?
    Boat: Criss-Craft Crowne 1997 (34ft)
    Transmission: Hurth ZF 63a (V-DRIVE)
    Engine: 2 KAMD Volvo Diesel
    Is it possible to remove the transmission with boat in the water?
    Looks like there is not enough clearance between shaft and the wall to remove the transmission.
  2. #2
    Default Re: HURTH ZF63A Transmission Removal?
    Give this company in Jacksonville FL a call called ADR Power Systems, I needed some advice and they were quick to help even though I did not require them to do the work
    (904)374-0196 and ask for Ricky
Similar Threads
  1. Hurth zf25
    By Malaya in forum Marine Transmissions and Reverse Gears
    Last Post: 08-05-2014, 11:31 AM
  2. Hurth V Drive
    By kevin_z in forum Crusader Marine Engine Forum
    Last Post: 04-29-2010, 08:53 AM
  3. Cheaking oil on hurth transmission
    By lugnutdan in forum Crusader Marine Archive
    Last Post: 06-10-2009, 10:29 PM
  4. Cheaking oil on hurth transmission
    Last Post: 06-10-2009, 08:26 PM
  5. Hurth 630 direct drive 3 gear transmission
    By chollyjohn in forum Miscellaneous marine engine topics
    Last Post: 09-13-2008, 11:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
