My buddy took his boat into a shop for yearly service, Motor is an 2008 F150 4 stroke with 250 hours. After Service, the boat was launched and ran on low idle (throttle position the entire time) in water canals for about 30 minutes when it died. After checking electronics we noticed the Oil dip stick showed no oil. The oil light never came on. We added 5 quarts of oil and the dip stick looked normal, however it still would not start.
I checked compression and each cylinder registered 30 to 34 psi.
The boat was taken back to shop and discovered the timing belt slipped. The shop said they replaced the belt and boat started right up. They ran it and the diagnostics on it came back clean. Temperature was good, and compression was between 180 - 190 psi on all cylinders. they also pulled the filter after the run and split it open to check for metal and non was found. The Shop did not charge him for fixing this.
My concern is that there could have been damaged caused to the CAM when motor stopped when timing slipped.
My question, should my buddy be concerned since the shop didn't pull the CAM journals to verify if there wasn't any galling to the CAM?
