Results 1 to 3 of 3
  1. #1
    Default Borg Warner Transmission model identification
    I have a borg warner transmission bolted up to 210 hp perkins diesel in my boat. Unfortunately there is no name plate on the tranny to identify its model. Are there any notable visual characteristics that I can look for that will help me identify the model type? I think it is a 71 or a 72 series and it is pushing a slow, heavy displacement lobsterboat hull. Also, I have noticed that there is a little lag or delay time between when I shift into gear and when the actual shift takes place. Any suggestion what is causing this and what the remedy is. Also what are the recommended tranny fluids for a 71 and a 72 series BW tranny?
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    3,143
    Default Re: Borg Warner Transmission model identification
    baitbag i'm not a diesel or a transmission expert, but maybe a few pictures might help others on this site help you
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,279
    I'd suspect it's a 72 series with a reduction gear....the 71's don't always handle the diesel's torque very well....
    I've always used the ID plate - it may have been painted over.....
    The shift is controlled by hydraulic fluid pressure once the lever is actuated....so I'd suggest starting with a fluid check and then a pressure test....you can find many pdf versions of the service manual via a www search.
Similar Threads
  1. 72c Borg Warner transmission on a 1987 Trogen 10 meter on the reverse rotation engine
    By Lisapantano9 in forum Marine Transmissions and Reverse Gears
    Last Post: 08-30-2016, 06:29 PM
  2. Borg Warner Velvet Drive Transmission
    By laro6688 in forum Marine Transmissions and Reverse Gears
    Last Post: 12-25-2011, 02:43 PM
  3. Borg Warner C2 transmission
    By swelch in forum Marine Transmissions and Reverse Gears
    Last Post: 12-24-2009, 09:25 AM
  4. Borg Warner 72c
    By blasttech1 in forum Miscellaneous marine engine topics
    Last Post: 04-23-2008, 11:45 PM
  5. Borg warner transmision to hot
    By just_ed in forum Archive 2002-2006
    Last Post: 07-17-2003, 10:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
