Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 6 of 6
    Default DT-5 Ignition issue
    I Have a DT5 (white cowl, red/orange decals Blu leg) wih no spark
    Main coil under fyweel 150 ohm
    triger coil under flywheel 25 ohm
    Main HT coils is sealed
    Any suggestions wht to replace
    Both nder flywheel coils generate AC
    thanks in advance
    Apr 2016
    barnegat NJ
    2,723
    Default Re: DT-5 Ignition issue
    Are the proper plugs installed and gapped properly,Has plug wire been ohmed out also
    Quote Originally Posted by johnnygjr View Post
    Thanks Johnnygjr
    I have the original plugs out shorting on chassis to test and HT leads are moulded into twin coil pack, but i will get new plugs :-)
    Apr 2016
    barnegat NJ
    2,723
    Was an open air gap spark test run ,just shorting plugs to block is not a thorough test for sufficient spark
    I've seen a set of inline HT leads with sliding pins for 6 Cyl 12v systems, but wouldn't plugs earthed outside the head be a good start?
    The CDI module is expensive so I want to rule out coils before I get one.
  6. #6
    Apr 2016
    barnegat NJ
    2,723
    An open air gap spark tester can be built with a piece of 1x4 or 1x6 a few finishing nails bent at right angles,alligator clips,solder and wires ala Joe reeves style, Maybe he will respond with the specifics all spelled out. Is battery fully charged? Engine must turn over between 200-300 rpm for stator to produce ignition spark, Hope this helps
  1. Ignition issue
    By Reidy in forum Mercruiser Sterndrive Forum
    Last Post: 09-27-2016, 12:35 AM
  2. ignition issue
    By a238killfish in forum Johnson Evinrude Outboard Forum
    Last Post: 07-26-2016, 06:47 AM
  3. Ignition issue
    By Larry302 in forum Pleasurecraft Marine PCM Forum
    Last Post: 11-18-2011, 07:35 AM
  4. 1994 Evinrude 40HP ignition issue? Engine reaches max RPM with ignition off!
    By jeralmac in forum Johnson Evinrude Outboard Forum
    Last Post: 07-09-2011, 12:21 PM
  5. Ignition issue
    By mn_native in forum Mercury Mariner Outboard Archive
    Last Post: 09-20-2008, 12:31 AM
