Results 1 to 5 of 5
  1. #1
    Default 1989 70hp Evinrude vro conversion to standard fuel pump
    I have my vro bypassed and now having a fuel issue which I believe the pump went out I'm wanting to convert over to a standard fuel pump using brp#0385784 has anyone done this? If so what all has to be done?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,108
    Default Re: 1989 70hp Evinrude vro conversion to standard fuel pump
    I would use the pump off a 1989 65 hp commercial model.-----Fuel into filter cap.---------Remove pulse limiter and install fitting for a pulse hose.------Fuel out to the carburetors.---------Fabricate a bracket to hold the pump.
  3. #3
    The pulse limiter that is ran with a separate hose to Port side of motor coming from vro with a valve for manual fuel flow or full run correct?
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,108
    I am not sure what post # 3 is talking about, not at all.-------Are you confusing the fuel primer valve ( red lever thingy ) for starting with the pulse limiter that is protection / flow fuse for the VRO fuel pump ?-----------------The electric primer is not touched / modified when you install a conventional pump.
  5. #5
    I'm sorry I think I know what your talking about now. Your talking about on the fuel pump you told me to use remove the pulse limiter from that and install and pulse hose connector ?
Similar Threads
  1. Vro2 pump conversion to standard pump
    By STEVEN N in forum Johnson Evinrude Outboard Forum
    Last Post: 05-14-2015, 09:20 AM
  2. Replacing VRO fuel pump on Evinrude 130 HP with standard fuel pump
    By Topkick8 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-03-2015, 09:07 PM
  3. 1957 Evinrude fuel pump conversion
    By Break-em in forum Johnson Evinrude Outboard Forum
    Last Post: 08-28-2013, 09:36 PM
  4. 1989 1990 Johnson 70hp Fuel Pump Hookup
    By billgiles2 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-30-2012, 12:46 AM
  5. 1989 Evinrude 70hp VRO fuel pump problem
    By joho5 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-17-2009, 08:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
