Have a 89 year Tracker Johnson Evinrude TE50TLCEC
Engine runs great! Just replaced the water pump just because I would feel safer with New pump!
I do not think I turned the shift rod to either lengthen or shorten!
If I did do I lengthen or shorten or trial and error!!
I did re-tighten a bolt in the Cam type junction that holds the small bolt that holds the shift rod in place (under the carb)
I'm wondering if this Bolt causes minor adjustments in the shift rod.
Help here will be appreciated!!!
Jennings
Jennings
