I had not tried starting this motor since last July and it had started and ran fine .Last week I decided to figure out why the throttle handle was so hard to turn and do a carb. rebuild.Well I pulled the flywheel thinking there was corrosion causing an issue under the plate the moves around when turning the handle, but it was ok and everything looked good under there.After doing the carb. and needing a new throttle cable and Cam follower assy and roller( I broke it with the pull starter install) I was sure this would just fire up no problem like always.Drove to the river and nothing but a flooded engine.No spark on either cylinder.Pulled boat out and even tried other plugs, no luck.Checked my lanyrd switch and it operates on an open circuit and it was still open and I even disconnected it to be sure.Could I have damaged something under the flywheel?Not much there to mess up since I did not do anything, but look at it.I am sure the key lined up fine.Could the CDI just went bad sitting since last July.Wish I had ran it first now!
