I own a 1976 Johnson 25HP Model 2576E In which the prop and shaft was spinning freely in reverse and forward so I thought that I had a problem with the lower unit. I did check the gear shift connections and it was moving up and down before trying to start it initially. Then I decided to start it up (in neutral) to see if the prop would actually spin in either gear. I pulled up on it twice and it wanted to start and run but on the third try the flywheel and the prop was locked up tight, so did something break and let go? What type of problem do you think I might have In the lower unit? How easy is it to remove the lower unit and the prop shaft components, any help, suggestions or videos.....
Seeking immediate help please
