nicklanigan
Hi all, I've had cause to do a bit of work on my starter motor as part of an overall rebuild, and have discovered a problem with my pinion gear on the starter. The replacement gear is on order, so all I'm looking for is some info on what is inside the pinion gear, and how it works. Like many, I enjoy learning and understanding about these matters.. My symptom to provide context is that the pinion assembly flies up beautifully, engages the flywheel perfectly, but then will struggle to actually turn the flywheel - however, the starter motor is spinning at full speed. The pinion is "slipping" on the starter shaft. The shaft thread and female mating thread are both in perfect condition. Potentially my pinion assembly is 40 years old.
Just to be clear - I'm talking specifically about the pinion gear assembly - I had always assumed this is one part, but upon removal, it is actually at least 3 components - I don't the names for any of them, so hopefully I can make it clear enough... there is the actual pinion gear that engages the flywheel, this is on the top. On the bottom, there is a female "nut" that has the female helical thread that mates with the helical thread on the starter shaft. And there is something between these two components - some kind of rubber bushing or a spring perhaps? I can't see an easy way to get the pinion and bottom nut apart to see what's inside. On my assembly, I'm able to easily turn the pinion one way and the female nut the other way - I imagine this is not meant to happen and is the slipping I'm seeing when using the starter.
So, I know that the female thread is the mechanism by which the pinion assembly is thrown up in the flywheel upon spinning the starter, and is the same mechanism that the pinion assembly descends on once the motor is started or power is killed to the starter.
What happens when the pinion is actually engaged with the flywheel though - presumably the female nut thread must stay engaged with the starter shaft thread, and transfer the torque to the pinion via the rubber bushing/spring in the middle of the pinion assembly? What is the purpose of the spring/rubber bushing - why not just have a single piece pinion gear that has a female thread on the inside? Is it to provide some slippage when a high speed starter engages with a stationary flywheel to avoid the starter stalling out? Impact absorption?
Rather a long question, but hopefully it makes sense.
Thanks,
Nick.
Thanks,
Nick.
