DeltaRanger
2006 225hp Mercury Optimax. The power trim works fine on the trailer and at idle. When running WOT, the motor trims up, but, seems to me I should be able to trim up more then it's current position. It used to trim up until prop would cavitate and start to loose water pressure. What would be the cause and repair.
Serial # 1B275976
Thank you.
Serial # 1B275976
Thank you.
