hi kg - yeah still have the instructions thanks, I think I got it sorted but the shift interrupt was def not working. Ill shout if im stuck -
Not sure what this canister thing is? There are 2 hoses that will screw onto this, not sure what it does, looks almost like a steering ram / assist or something?
Ill be removing the steering cable today to see if its binding while disconnected - and maybe lube it up and order something next week.
kghost - fyi, I used this method from my outboard (similar) for a fast setup: (just figured it myself)
Disconnect the helm steering cable from the engine bracket with helm ctrl in Neutral / locked position - Disconnect Battery(!)
** The lower cable has to be connected and assembled correctly of course / shoe / lower unit spline etc)
** The lower cable is never removed or disconnected, only the end eye from the helm cable is removed from engine bracket.
Now:
1: Have someone
rotate prop backwards / counter clockwise (looking from behind motor)
2:
Slowly push bracket/lower cable in towards Fwd position till the gears start to click/contact each other,
make a mark on the
lower cable sleeve
3:
Rotate prop clockwise (looking from behind motor) and pull bracket/lower cable (towards Rev position) till it starts clicking - again
make a 2nd mark on the same sleeve.
4:
Between these 2 marks is the
exact neutral mark on motor
5: Adjust the bracket till the
lower cable sleeve is in the
middle of these 2 marks
6: Lastly adjust helm cable barrel without moving the bracket / lower position and bolt in place.
Using the bracket gives a bit more leverage and makes it easier to get to the contact point of the gears -
The helm control is now perfectly adjusted to the neutral position on the cable/motor considering all variables of wear in helm AND joints / cables / etc..
Assuming your cables are not toast of course - this will get you perfectly in the center of the shifting margin for Fwd and Rev.
Works fine - just have to sort out the shift interrupt - hopefully back on the water today
Not sure what to do about steering - will report back today as well.
