Hi There - I am trying to help a friend troubleshoot a 2007 Tohatsu 5 hp (Model MFS 5BS). He's had it for a year and it ran fine until recently.
Problem is it runs for a few minutes and then sputters and dies.
I checked oil - it was a little high so I drained some. Now it is not above top line at all.
I removed and cleaned carb. Not much gunk at all, but did notice oil on the air intake - side closest to fly wheel where tube from crank case comes back to top of intake.
After lowering oil level and cleaning carb, I took it back to the water and it started great - idled in neutral and ran at mid range rpms in neutral for 10 minutes. Thinking I had solved it - I put it in gear and it sputtered and died within 1 minute. A white puff of smoke and small backfire come out of air intake when it dies.
What's up??
Thanks!
What's up??
Thanks!
