Results 1 to 2 of 2
  1. #1
    Question 1947 firestone 3.6hp trouble accessing points condenser etc
    I recently acquired a firestone 3.6 hp motor. I was told all it needed was to clean and reset the points and lower unit grease. so far i have removed the fuel tank lower shroud. I have removed the nut and washer from the top of the housing for the points but the bell housing that goes on top of the points wont seem to come off. there is maybe an 1/8" of slide and then nothing. Am i missing something?? I tried uploading a picture but can seem to get it to load. Any help is greatly appreciated.
  2. #2
    Default Re: 1947 firestone 3.6hp trouble accessing points condenser etc
    You did not say, but I am assuming there is no spark. What you call the bell housing is the flywheel. You can rent or buy a flywheel puller to remove it. Once it is removed you can clean and set the point gap at .020 with a feeler gauge. If you have a multi-tester you can check the coil and condenser. Replace the flywheel and check for spark. Also, check the plug wire for breaks.
Similar Threads
  1. BF75 or BF100 Points Condenser Help???
    By jduck1 in forum Honda Outboard Forum
    Last Post: 03-07-2015, 11:28 AM
  2. points and condenser for early 80s Chrysler 15hp
    By flamecensor in forum Chrysler Force Outboard Forum
    Last Post: 08-14-2013, 07:22 PM
  3. Need parts info. Points/condenser. 1967 Ted Williams/McCullough 9 hp.
    By randyj in forum Identifying Model / Year / Horsepower
    Last Post: 03-26-2011, 11:32 AM
  4. Another 1954 Fleetwin question re points condenser
    By gnshowzaolcom in forum Johnson Evinrude Outboard Archive
    Last Post: 12-10-2009, 07:16 PM
  5. Condensor and points for 1947 Montgomery Ward 5hp
    By randyfish37 in forum Archive 2003-2009
    Last Post: 07-24-2007, 05:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
