Going broke
Need some help my 200hp when cold will start and idle great and will top out great after a few min it will idle different and will not get on plane I can hold it to the floor and it may go a min or 20 min then it will pick up and go sometimes it will cut out again it's very sporadic
took it it to a local guy I've known for years and ran some tests
good compression
good fire
tps right
new fuel filter and line
rebuilt low pressure pump
stador was bad replaced it
cleaned out the vct
and he checked the ecu
new water separator it did have water and bad fuel in it
new plugs
had it at a different shop to put new carpet in it and they where supposed to service the motor
plugs
filter
lower unit oil
they said they had to clean the injectors to get it started but they didn't put new plugs and lower unit oil or a new water separator
good compression
good fire
tps right
cleaned out the vct
new plugs
plugs
filter
lower unit oil
