Results 1 to 6 of 6
    Default Outboard Fuel Pump Repair
    I own a Mercury 25HP Big Foot 4 Stroke....the fuel pump is leaking so I ordered a new cover gasket and a new diaphragm. I have some of the Permatex gasoline resistant gasket sealer. Would it be advisable to use on the cover gasket??? If so, should I put the sealer in the cover and then fit the gasket into the sealer or, install the gasket in the cover channels and apply the gasket sealer over around the cover gasket. Also, should/could I use the sealer to hold the diaphragm in place while putting the fuel pump cover back on the assemble?
    Oct 2012
    sacramento, ca.
    306
    Default Re: Outboard Fuel Pump Repair
    no sealer
    *** In comparing the virtues of various calibers, using hollow point ammo: it is absolutely undeniable that, while a 9 mm or .40 S&W may or may not expand, a .45 will never shrink. ***
    Dec 2015
    maplevalley WA
    5,046
    Lightly surface the covers with 220 grit on a glass table by just pulling it in one direction only. Do not use sealer anywhere on the fuel pump.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
    I did use a dab of grease to hold gasket in place but, the diaphragm and gasket were easy to fit in place and the fuel pump went back together so much easier than I anticipated.....motor is running good and fuel pump is not leaking....Thanks crankbait
  6. #6
    Apr 2016
    barnegat NJ
    3,143
    Happy boating,major dad
  1. fuel pump repair????
    By farmerrick53 in forum Mercruiser Sterndrive Forum
    Last Post: 05-28-2016, 10:52 PM
  2. BF50A Fuel pump leak-repair or repace
    By Pinehill in forum Honda Outboard Forum
    Last Post: 05-10-2016, 08:12 AM
  3. Put a fuel pump repair kit on fuel pump 93 evinrude 6hp
    By big cat 67 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-08-2012, 05:51 PM
  4. Repair info on 1994 70h Johnson outboard water pump.
    By Carole M. Edwards in forum General Boat Repair Topics
    Last Post: 06-13-2011, 09:07 PM
  5. Fuel Pump for Elgin Outboard
    By Robert J Lee in forum Outboard motors archive 2000-2004
    Last Post: 11-24-2002, 02:58 PM
