Results 1 to 9 of 9
  1. #1
    Default Throttle/shifter Problem
    I have an early 16 ft. 140hp inboard/outboard Jolly Roger Boat. It has a Mercruiser out-drive and I am trying to connect the shift cable which was not hooked up. I bought the boat for near nothing price. I understand that someone changed the motors but didn't get the throttle/shift cables hooked up. I have had the motor started and it runs sweet. The only problem is it won't start in neutrol. It has to be in forward or reverse to start and throttle up. I figure I need to reach out and make sure I have it hooked up right? The shifter is a single throw T handle with a button under the handle. Any help would be very helpful. Thank-you.
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,855
    Default Re: Throttle/shifter Problem
    Kinna sounds like a start safety switch is wired backwards. If its aftermarket it could have three terminals you want the two that are normally closed. The switch will open in forward or reverse to keep the starter from turning. Pull the controls apart and take a pic of the safety switch.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,881
    without specifics, hard to say what you have let alone what could be wrong.
    if the wiring follows the Standards, the key switch will have RED (+12VDC from battery), PURPLE - Ignition to coil, and YELLOW/RED - +12VDC to starter. The YELLOW/RED wire usually leads to the neutral safety switch and then the starter (many times thru a 'slave' relay).
    Id suggest getting out a test light and figure out where the error is.
  4. #4
    I guess I should have been more specific that I need to know which cable goes where on the engine. I don't believe wires has been touched around the neutral safety switch, at least there is no indication that they have been tampered with. I am the one that hooked the cables to the engine and am questioning my work.
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,855
    The safety switch is working backwards you probably have it wired properly. Take the controls apart and show us pics of the safety switch. You probably have the mercontrol box get some marine grease and clean it up good and replace any bushings that may be shot while you have it apart. There is a detent roller and spring that holds it in neutral you need to be aware of when you take it apart.
  6. #6
    Again my question is, back by the engine there is two cables one I believe is a shift cable and the other I think is the throttle cable. I hooked them up BACK BY THE ENGINE, I am not sure that I have them hooked correctly so that is why i am asking.
  7. #7
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,697
    Quote Originally Posted by ivanhoe View Post
    Back by the engine there will be three cables not two. Two from the control box and one out to the outdrive.
    Two cables from the control box, Move the control box from Neutral and the first cable that moves is the shift cable. Move the control box further and the throttle cable will start to move.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  8. #8
    Thank-you that is what I needed to know. All the other talk about neutral safety switch was not part of my problem.
  9. #9
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,855
    If your safety switch is not working properly people can die. It is your responsibility to make sure the boat is safe, it is always the innocent who get harmed from someone elses ignorance.
Similar Threads
  1. Throttle and shifter adjustments
    By Barry63028 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-20-2016, 07:38 PM
  2. Throttle/Shifter Jammed
    By Whaler15 in forum Mercury Mariner Outboard Forum
    Last Post: 11-11-2014, 10:57 AM
  3. Throttle/shifter controls
    By jrbass in forum Boat Steering and Engine Controls
    Last Post: 01-20-2013, 10:02 AM
  4. Repositioning throttle/gear shifter
    By am_dew in forum Volvo Penta Gas Engine Forum
    Last Post: 07-06-2010, 08:19 PM
  5. Stiff Throttle Shifter
    By mike in forum Archive 2003-2009
    Last Post: 07-11-2002, 12:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
