Results 1 to 3 of 3
  1. #1
    Default How tight/torque spec
    How tight should I make the prop nut?I took prop off and it was loose when I went to check it.Just took it off by my fingers.I assume the nylon washer just wore away some and it was loose from that.
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,901
    Default Re: How tight/torque spec
    Not knowing what type of engine you have but most are 50-75 ft lbs....torque flow hubs are 100ft lbs
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  3. #3
    thanks-20hp
Similar Threads
  1. Torque spec - TIGHT vs DRIVE TIGHT?
    By NorthShore in forum Mercury Mariner Outboard Forum
    Last Post: 01-08-2017, 07:48 AM
  2. Torque spec?
    By Tnmoutdoors in forum Mercury Mariner Outboard Forum
    Last Post: 01-12-2016, 08:12 PM
  3. torque spec 135 hp
    By lucp57 in forum Mercury Mariner Outboard Forum
    Last Post: 07-15-2011, 08:36 PM
  4. Torque spec
    By lcboom in forum Mercruiser Sterndrive Archive
    Last Post: 07-29-2009, 03:14 PM
  5. Torque Spec
    By evinrude395vs in forum Johnson Evinrude Outboard Archive
    Last Post: 02-23-2009, 10:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
