Results 1 to 4 of 4
  1. #1
    Default prop repair or buy new
    New prop is about twice the price of rebuilding one.Are repaired props good enough and worth saving the money?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,969
    Default Re: prop repair or buy new
    I sometimes see props with multiple numbers on them.-------Each # is a repair invoice.-----------Props that have been repaired 3 times or more may be risky.-------------If your propshaft is straight and you do not operate in risky / rocky shallow water go for a new prop.---------On the other hand if you are on the bottom a lot then invest in 2 used ones.
  3. #3
    I am in a very rocky river, but have just had a prop guard welded up.I was told the vibration fom the bent and chipped up prop is hard on the engine.Guy at marina just laughed when he saw mine and said it looked good compared to a lot he sees come in.I had to agree after seeing one on his lot.There are small holes in it from cavitating I assume near the chips and dings.
  4. #4
    Join Date
    May 2011
    Location
    slough ,berkshire uk
    Posts
    161
    a good prop shop who spe******es in repairs and prop tuning will make it as good as new.
    I not sure then buy a stainless prop, get a good used one an enjoy the benefit of stainless props, they are just so much better than alloy.
    Make it ultra sharp and you can keep the same pitch.
Similar Threads
  1. Opinions on talking to repair shop about a repair
    By Dave12 in forum Mercury Mariner Outboard Forum
    Last Post: 04-01-2016, 08:53 AM
  2. Prop shaft repair Evinrude E90DPSLOR
    By grimesinma in forum Johnson Evinrude Outboard Forum
    Last Post: 04-03-2014, 10:06 PM
  3. Prop tunnel repair help?
    By gre0005 in forum Boat Hull, Deck and Transom Repair
    Last Post: 12-13-2012, 09:48 PM
  4. Prop and skeg removal for repair
    By tamike in forum Volvo Penta Gas Archive
    Last Post: 09-10-2007, 06:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
