Willispwillis
Hello first post please forgive if it's a repeat. I have a 1994 johnson fast strike that the tach will work intermittently along with the voltmeter ( indash) reading 17-18 volts and not always together. Sometimes the tach works normal and volt meter stays around 12 other times both gauges jump up together the tach appears to read correctly. Any advice would be greatly appreciated. The voltage regulator was changed around a year and a half ago still looks very good all wiring is clean and tight from battery to instrument cluster. Thanks in advance.
