whitegreg56
It's serial #0G149543. Nothing is locked up and all the springs are present and working.
When the handle is pulled, the pawls start to move out, but then stop before engaging the flywheel.
It looks like there may be too much lubrication between the sheave turning and the cam plate that pushes the pawls.
Or, maybe the spring loading of the cam plate is too weak.
Can I pull the cam retainer bolt out, in order to clean and grease, without the whole thing
flying apart on me? The Factory Service Manual has the starter rope coming out....not sure
if that is actually needed.
Also have a 1998 that seems to be developing similar trouble....this must be quite common.
Hoping I don't have to purchase a whole new starter assembly!
