Results 1 to 3 of 3
Thread: Prop Question
  1. #1
    Default Prop Question
    Hi everyone.. Now I've got my evinrude 25 xp running nice its time to replace the prop as it's seen better days.. currently running a 10 x 13. dose anyone here know if there are any better options to possibly squeeze a little more top end out of the engine..
    Thanks all..
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,908
    Default Re: Prop Question
    It all depends upon your Wide Open Throttle RPMS, Check owners manual for specs. you will need a tachometer to ascertain this reading, If your running RPMS is at the bottom of this range a higher pitch of one inch theoretically should give about 200 RPM increase. Make sure cavitation plate is level or about with keel of you boat,not below
  3. #3
    Looking for a prop 1967 5 up Johnson mod LD12A PART number 380104 thanks Joe
Similar Threads
  1. Prop size question and off shore style prop on a through hub exhaust?
    By H2oallyear in forum Propeller Selection and Replacement
    Last Post: 07-25-2014, 07:07 PM
  2. Prop question
    By am_dew in forum Volvo Penta Gas Engine Forum
    Last Post: 05-13-2010, 12:57 PM
  3. Duo prop to single prop question
    By glastron24css92 in forum Volvo Penta Gas Archive
    Last Post: 07-23-2009, 12:39 PM
  4. PROP QUESTION
    By stewsbs in forum Volvo Penta Gas Archive
    Last Post: 10-04-2007, 11:53 AM
  5. Prop question
    By davespades in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-29-2007, 11:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
