DanOverboard
Hello,
My 1996 NS5B started leaking a small amount of oil from around the prop, so seemed like a shaft seal. (This motor is used on the dinghy for my sailboat so it mostly lives out of the water and on a bracket on my stern rail)
I drained the gear oil and it was a bit milky but the gears and everything inside look fine.
I got the lower unit off and bearing carrier out and as far as I can tell the shaft bearing needs to come out (inward) to get to the shaft seal behind it. However, I can't figure out how to get that bearing out. I don't see any corrosion and I soaked it in liquid wrench but it just won't budge.
This is my first time doing this. Is there a trick to it? Is there a tiny puller that would fit in there to pull the bearing out?
Thanks,
Dan
Thanks,
Dan
