Well an update, A late one but takes me forever to get parts and I was missing an oring so didn't bother with this for a while, I set the rolling torque value on the double bearing box using the values On page 171 of the online manual,
ended up being 1.75 lbs after adding a
005 thou shim and a 10 thou one, checked the gear back lash ( Dial indicator) and it was .006.5 thou, that's pretty close to max, so Ricardo would you have added a shim to tighten that up a bit?, the gear pattern seemed good as compared to the manual, I tryed to take a pic of it but didn't show up that well, I was using Prussian blue ( don't know if there better stuff out there ) well now I'm onto the lower gear seals ( prop shaft) it's going smooth so far using Ricardo's little puller, well a rougher version of it. Just need to get orings and seals and put it back together. Ricardo and Kim I want you to know how much I appreciate you guys taking the time to help people like me and others so thanks to you both
Kilwinning
