Results 1 to 4 of 4
  1. #1
    Join Date
    Jun 2009
    Location
    italy
    Posts
    56
    Default need help from Italy
    Hi all,
    I am rebuilding a 1962 chevy 283 and I need an affordable seller for a rebuild kit
    Anyone can suggest to me one?
    thank you
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,656
    Default Re: need help from Italy
    http://www.ebay.com/itm/1963-1967-Ch...gMqCaA&vxp=mtr
    Have you tried ebay? You can get complete kits with the correct bearings and pistons. You will need to have the block bored over and the crank ground under. Have your machinist mic out the cylinders and crank and then give the pistons and bearings to the machinist so he can get it to spec. Be sure and check end gap on the piston rings and plastiguage the bearings before final assy. Install a high volume oil pump if available.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,656
  4. #4
    Join Date
    Jun 2009
    Location
    italy
    Posts
    56
    thank you kimcrwbr1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
