sandkicker
Outstanding Contributor
Specifically for a 280 drive, is there a hex head (allen) alternative to this???
I use a large flat tip screwdriver and a cresent wrench. You can push in hard with the screwdriver and turn it with a wrench. Install new o-rings at least every other time you pull the plug or dip stick.
I believe the thread is SAE so I think it would be an alternative. It's a good idea - I think I'll check it out.
That's what my 280 takes...check Home Depot or Lowes.Ayuh,.... Should be the same as 99% of the drain/ fill screws out there,....
3/8" - 16,.....
Why re-invent a wheel that works well?
I have never come up against an AQ series OEM drain plug that could not be removed with the use of my hand-held imact driver.
Suggestion: get yourself a hand-held impact driver and several of the correct sized straight slot bits for it!
BTW, most all threads on these drives are US NC threads....... not SAE nor Metric.
Only a few are Metric!
Found one w/allen head online for an E-TEC (Sierra 18-4255). It's very inexpensive.. Will see if it fits. Could not find specs on thread, and for the price, not worth any further research. Stay tuned...
Nice day, so I went for it! It (Sierra 18-4255) fits perfectly. Comes with two washers, one nylon , the other an O ring.I got it today.... soon as the weather breaks, I'll get someone to break the existing screw loose and give it a try.
