AndyM in Ohio
I have a 2001 BF50--runs fine, but --two items:
1) Found water in gear oil mid-summer. Drained (some metal, not a lot), flushed, refilled with fresh oil, and ran fine rest of summer. I pulled the lower unit to work on now. I pressurized the unit (8-10 psi) and the only leak is the shift rod seal. Should I simply replace the shift rod seal ? I installed a new water pump /seal kit two seasons ago. I don't plan to keep this boat for many more years. Or, should I have the lower unit rebuilt ? It makes no odd noises, shifts fine, and seems OK.
2) Have noticed a gas occasionally seeps from the layers of the fuel pump. It's not a lot, and it's not all the time. I wonder if simply tightening the 4 bolts & nuts will be sufficient (at least worth a try ?) , or do I need to get a rebuild kit, or just replace the pump.
Any advice appreciated.
