Click for Chrysler parts and manuals!
Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2009
    Location
    Chagrin Falls, Ohio, USA
    Posts
    17
    Default M460 spec info needed
    Looking at a potential vessel and need the following spec's on this model Chrysler M460 (Ford)
    1. Torque chart with RPM
    2. HP rating @RPM
    3. Hydraulic or solid lifters
    4 Fuel consumption per hour
    Also any feedback on these motors good and bad.
  2. #2
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    783
    Default Re: M460 spec info needed
    Not Chrysler but some 460 specs in the '89 PCM here................
    http://www.correctcraftfan.com/reference/manuals.asp
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,472
    Ayuh,.... Lotsa parts are NLA for the 460,....
    Exhaust manifolds for example,....
  4. #4
    Join Date
    Jun 2006
    Location
    Westford, MA, US
    Posts
    33
    Sorry to be a bit late to the party but - Chrysler M460 is the BBF with Chrysler marinization. Lots of parts available as long as you know the correct year (internal vs external balancing) EXCEPT as Bondo noted, the exhaust manifolds. I found very expensive replacement manifolds at CP out in California. Someone else made a log manifold (can't locate my records right now). These engines are used a lot for jet boat racing. Check the Ford 460 Forum for lots and lots of info.
    Gene
Similar Threads
  1. Info needed please!!
    By ray1 in forum Johnson Evinrude Outboard Forum
    Last Post: 07-06-2012, 06:23 AM
  2. Chrysler M460 plug wires
    By johnkmetz in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 08-04-2008, 09:00 PM
  3. Info Needed
    By tom_anderson in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 09-26-2007, 08:44 PM
  4. OMC compression spec needed
    By alan in forum Outboard motors archive 2000-2004
    Last Post: 12-09-2002, 10:18 AM
  5. Info needed
    By josh hildreth in forum Outboard motors archive 2000-2004
    Last Post: 07-20-2001, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
