I have read all over and as much as I have read I can't find any thing, maybe I just don't know how yet, anyways if someone can redirect me to a thread or maybe answer my question I appreciate. I have a 86 model 45 mariner and it just stoped running, took it to a boat garage with a 50 horsepower mercury that I bought for parts and the man told me they were both junk and the motor wasn't worth fixing, now I have used this motor in the river all the time, so I couldn't understand how it was junked out, well after looking At these motors for a year I decided to fool with it some not figuring I could do anything with it cause they said it couldn't be fixed cause the cost wasn't worth the motor, it would crank and crank and would not get any spark, so after reading on here for s long time about some of some similar problems, I decided to change the staitor and the trigger off of the two, now I still had the same problem except now the motor ( no crank) or power trim would not work .so then I read to unplug the wiring harness and try to jump it over and I did and it started right up. With amazement I was so excited, so I choke it turn it off, go to key switch and nothing, so i ran a test to my key switch and nothing , no choke, no power trim no power on any of the wires, I ran a hot wire straight from the battery to the red wire and the red-yellow wire and everything seem to work well power trim, choke everything cranked it and it tried to fire once then nothing, unplug the wiring harness and jump it over run great. So my question is it seems to me just like the kill switch or something is grounded how would I check to find this out or maybe it is in my key switch or wiring harness, since the thing runs when the big plug is unplugged, could there still be something wrong with staitor trigger or possibly anything else. I may not fix this thing but I've learned a little more than I used to know. Any suggestions what to do next.
