New to this Forum and just purchased a 17' bass tracker about 3 weeks ago....... Long Story short, Before the last trip on Saturday to San Diego bay my boat started and ran fine via the key start/electronic ignition. My 1993 Mercury Tracker 25hp was doing fine the whole trip until mid way through when the engine was cold I had to adjust the choke as usual and it took a series of 4-6 times of attempting to turned it on over the course of say 10 minutes before it kicked on. When I got home to start the motor to flush out the salt water it wouldn't turn on via the key for anything. So I used the pull start cable and it started after a few pulls and sounded good, flush it out for a bit and then shut it off and plugged the batteries in.
When I tried to start it up today via the key start, what looks like the small starter motor (has gears connected to the pull start gearing) it sounds very weak and is not able to crank the motor up. I looked at the SFE 20 fuse and it looks fine. Batteries test out fine. Any thoughts or ideas before I have to call a mechanic would be most helpful. I also have a short video of what the engine is doing when I turn the key if that helps at all. Thanks again!!!
Mike
Mike
