Regal fastback transducer location
burls
I have a Lowrance elite combo which l am fitting to my 2100 Reagan bowrider. It is a fastback hull which is designed to run air under the rear of the hull.
whare should l mount the transducer?
Have you looked into a thru hull transducer? You would need to cut a access hole in the deck and mold it into the hull just in front of the lowest part sitting in the water.
I didn't realise there was a difference until today. I will enquire at the shop today as to what they have
Fazt
True it can be mounted on the transome but from my understanding the design of the hull make it useless when on the plane. Lowrance have a transducer that can be mounted on the inside of the hull forward of the step for about $220, it is only a down scanner but l am leaning toward this option
