Charging 98 Johnson 115 ?
The ignition system does not use the battery when trolling,your accessories use the battery,fishfinder,radio,lights,vhf,bilge pump,etc
I have only one 70amp battery.
Possible for you to explain "deep cycle with a battery isolator switch" to a man who only use the boat and not have mutch experience with outboard......
A deep cycle battery is a lead acid battery,designed to be regularly deeply discharged using most of it's capacity, In contrast,a starter battery[e.g. most auto batts.]are designed to deliver short bursts for cranking the engine,thus frequently discharging only a small part of their capacity. A deep cycle battery uses thicker plates. Balder yes one for starting and one for everything else
