I have a 2002 Mercury 40hp...2 stroke...two cylinder.
it has a slower than rpm knocking sound when put into
forward or reverse. NOT in nuetral...NOT when prop is off...
NOT when rpm is bumped up 300 rpm.
(the prop spins free and no sound in Nuetral)
(In Forward, the prop clicks on the dogs one way, and turns
the engine over hard the other way.like it should)
(In Reverse if I turn the prop either direction, it turns the engine
over hard.it does not click on the dogs if turned counter
clockwise."SHOULD IT"?
if I put it in Reverse manually or with the remote cable I have
the same result!??
(I changed the lower unit oil and it was a clean as when I put it
in a year ago. The magnetic drain plug had nothing on it.)
the same result!??
