Temperature sensor
To test if the warning horn is working just short the wire to the temp switch to ground with the ignition on the alarm should sound.
I need the part# for the heat sensor for a 1997 60hp mercury 2 stroke.... motor ser#06482870...
Hi and welcome to marineengine.com.
The serial number posted is slightly incorrect. The 6 should be a G making the number 0G482870 which makes the engine to be a 1997 MERCURY 60 ELHPTO model number 1060411TD...Here is your parts catalog, http://www.marineengine.com/parts/mercury_marine_parts/sn/0g482870 ...http://www.boats.net/parts/search/Merc/Mercury/1997/1060411TD/parts.html
The temperature sender is Merc part number 78799 2 item number 30, http://www.marineengine.com/parts/mercury_marine_parts/sn/0G482870/1060411TD/1680_150
http://www.boats.net/parts/search/M...411TD/CYLINDER BLOCK AND CRANKCASE/parts.html
Oops I became distracted during the search and didn't realize the info was already taken care of before posting. :)
I want to add a temperature gauge and sensor for the gauge. I just need to know what is the part# of the sensor i need to add a temperature gauge.to my Mercury 1997 60hp 2 stroke ser# 0G482870.
Your looking for a temperature sending unit for a temperature gauge on your dashboard,correct Elkmontbrown? Not sure it's the same part as above
