Justmeagain
I have a 2004 Yamaha F225TXRC. There are 330 hours on the engine. After spending $3500 at a Cocoa, Fl. place, my issue remains the same. I'm not the type to return to the scene of a crime, or if a Dr. cut off my left arm instead of left leg. Why would you expect better results? Cooler now, I'll work it.
Symptoms: I used the boat infrequently, mostly run the engine monthly. The fuel tank was drained and cleaned. The engine ran well at idle at the dock for a time, now it will struggle and die. My son noticed that the fuel filter bowl in the engine drops below the filter element about half way down the bowl just before it dies. I can turn the key off and it will restart and run immediately. When it first starts to struggle, pumping the fuel primer bulb helps.
Actions: The shop did a full annual service. Injectors were removed and ultrasonic cleaned, one was replaced with a new Yamaha injector. Plugs are new (I did that) and good. Removed the VST and cleaned it. The fuel pumps were tested on the bench. They did run the boat on open water tests using a gas can direct to the engine. During the open water test, the engine bogged down at 3500 RPM. Fuel pressure fluctuated, drops to 35PSI under load. High pressure fuel pump was replaced and the VST, screens cleaned.
The fuel filter is new. It has a bowl and drained several oz. and it was clear. New fuel is non-ethanol. I do have a Yamaha fuel flow sending unit installed just after the fuel filter. I removed it, I'm wondering now if the paddle wheel is sticking. That could account for the sudden stall after traveling 1/2 mile but not the 3500 RPM limit. Haven't tested it yet. I also noted when the engine wants to die, pushing up the throttle up only worsens the situation.
Any insight would be appreciated.
Also, any experience with the diagnostic sets (pigtail and SW) available from E-bay vendors? Seems they are all out of the country.
