would there be any benefit fitting an oil cooler to a 5ltr mercruiser v8 1985 vintage,coolant temp is constant 150deg f the air temp under the engine cover is very hot,i would run the cooling hoses to another power steering cooling adaptor in the raw water hose,before the heat exchanger,the eng is fresh water cooling.
