Results 1 to 3 of 3
    Default Rocker arm bolt sealant necessary? 7.4 MIE
    1995 Mercruiser 7.4
    Inboard
    ser; 0F563022
    just found a manual that says to use perfect seal, I only used a sealant on the head bolts thru the water jacket. Didn't think the bolt holes for the rockers were in the jacket. These are bolts not studs.
    Will I see any problems if I leave them alone?
    Sep 2008
    Maryland - USA
    6,884
    Default Re: Rocker arm bolt sealant necessary? 7.4 MIE
    I'd suggest getting another manual....
    Factory manual doesn't mention applying anything to the bolts.....as long as you didn't over torque them, you should be good to go.
  1. Valve Stem Seal on Rocker bolt?
    By Tommiman in forum Yamaha Outboard Forum
    Last Post: 06-24-2013, 04:03 PM
  2. Rocker Arm Assembly
    By Trojanman in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 12-22-2011, 08:14 AM
  3. 454 - 4 bolt or 2 bolt main bearings?
    By pgall in forum Crusader Marine Engine Forum
    Last Post: 04-26-2010, 10:55 PM
  4. 318 Rocker Arm Assemblies
    By markkingscraft in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 06-12-2008, 05:44 PM
  5. Broken Head Bolt How Do I Remove This Bolt
    By vette_61 in forum Mercury Mariner Outboard Archive
    Last Post: 03-11-2007, 11:58 AM
