Results 1 to 5 of 5
  1. #1
    Default Sears Clinton made 1968 3hp
    Trying to get the correct settings for the high and low needles.
    Motor runs but I'm having trouble getting it to idle. And it's shutting down at high speed.
    Thanx in advance
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,656
    Default Re: Sears Clinton made 1968 3hp
    Pull the fitting out of the fuel tank and clean the strainer. If it cannot be used just put in a inline filter to the carb and cut the strainer off. Then rebuild the carb or just clean it good as long as the float and needle and seat are working good. If you have the cork float lightly sand it smooth and let it gas off good then dunk it in a small dish full of model airplane clear fuel proof dope and let it dry for at least 24 hours.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Thanx for the response. I don't have a fur issue... it runs it just need the right settings on the high and low speed.
    I'm currently posting the new video of the motor running great!
    Found a a sweet spot I guess on the needles.
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,656
    Make these adjustments on the water first adjust the slow needle for a smooth idle then take it WOT and adjust the high speed then back to slow and adjust the needle again. When adjusting turn the needle 1/8 turn and wait about five seconds for the crankcase to stabilize. You can preadjust in a barrel but it needs to be on the water to adjust the high speed properly.
  5. #5
    Thanx again! I will check everything on her maiden voyage! I'll try and document
Similar Threads
  1. Sears model # 20458220 made in japan
    By eskaguy30525 in forum Other Outboard Motors
    Last Post: 12-26-2008, 02:22 AM
  2. 7 hp Sea King Clinton made prop
    By mikeyt3 in forum Clinton Outboards
    Last Post: 07-09-2008, 11:12 AM
  3. 7 hp Sea King Clinton made prop needed
    Last Post: 07-03-2008, 07:01 AM
  4. 35hp Sears outboard Who made it for Sears
    By Rick McAllister in forum Archive 2003-2009
    Last Post: 04-26-2007, 10:27 PM
  5. Replies: 1
    Last Post: 06-10-2006, 05:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
