Click forPleasurecraft Marine parts and manuals!
Results 1 to 8 of 8
  1. #1
    Default To anti seize exhaust manifold botls or not?
    I have read so many different opinions on whether or not to use anti seize on the exhaust manifold bolts. I need to replace mine now and am not sure whether or not to use it and if so what type/brand do you recommend? (please excuse the typo in the post heading...oops)
  2. #2
    Join Date
    Apr 2013
    Location
    Lower Columbia River
    Posts
    100
    Default Re: To anti seize exhaust manifold botls or not?
    I replaced my exhaust manifolds earlier this year. I, too, struggled with the question of using anti-seize or not. In the end, I applied a little to the last section of each bolt's thread that would contact the head to (hopefully) seal out any liquid that might work its way down the bolt. I think my current can of anti-seize is a Permatex product and it's worked fine.
    Dan
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,472
    Ayuh,.... I coat the threads with quicksilver perfect seal, or form-a-gasket #3,....
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    When you lube the threads it takes about half the torque value so keep that in mind you dont destroy the manifold gasket/s. Pull the manifold down slow and even with a center out pattern.
    http://www.portlandbolt.com/technica...-torque-chart/
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  5. #5
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,814
    First...... understand that there are two categories for these products.... Auto and Marine.
    The Automotive version of Anti-Seize/Never-Seeze may contain aluminum, copper, graphite, etc., suspended in an oily product.
    The Automotive version is excellent at/on warm/hot engine related fasteners, and is NOT intended to be used below the water line!
    When subjected to water, the aluminum, copper, graphite, etc will cause issues!
    The Marine version of Anti-Sieze will not have these components and will be more of a rubber-cement type viscosity (much like the QuickSilver "Perfect Seal"), mainly intended to prevent corrosive water intrusion. This version is intended to be used below the water line.
    I would NOT use it at/on warm/hot engine related fasteners.
    In asnwer to the thread question...... YES ..... Automotive Anti-Sieze or Never-Seeze is a very good choice for exhaust manifold fasteners.
    I would use caution in areas of potenailly wet threads, such as some Manifold-to-Elbow fasteners.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  6. #6
    Thanks to all of you for your responses. I will use anti seize on the manifold bolts, but not on the riser bolts.
  7. #7
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,814
    Quote Originally Posted by cbartle60 View Post
    If your Exhaust Spacer/Riser and/or Elbow female bolt threads are "dead ended" (meaning dry and not potentially wet), you can safely use Anti-Sieze.
    Just make sure that you use the Automotive version.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Exhaust riser space vs elbow explained 5 .jpg
    Portland, Oregon
  8. #8
    Got it...thanks again.
Similar Threads
  1. Tell me about "OMC Gasket Sealer Compound" (anti-seize properties?)
    By pilotart in forum Johnson Evinrude Outboard Forum
    Last Post: 12-11-2015, 10:27 AM
  2. Tell me about "OMC Gasket Sealer Compound" (anti-seize properties?)
    By pilotart in forum Yamaha Outboard Forum
    Last Post: 12-09-2015, 09:17 AM
  3. 91 454 riser /elbo reassembly... Grease studs? Anti seize, gasket seal rtv
    By slauder in forum Crusader Marine Engine Forum
    Last Post: 06-07-2013, 10:27 AM
  4. Anti Seize. for head and head cover bolts
    By Keithm18 in forum Johnson Evinrude Outboard Forum
    Last Post: 07-03-2012, 09:11 PM
  5. Torque anti seize
    By pwolf in forum Johnson Evinrude Outboard Archive
    Last Post: 08-26-2009, 05:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
