Results 1 to 9 of 9
  1. #1
    Default Need internal wiring help with old 12/24 brute
    Looking for some insight on what the wiring diagram for the foot pedal of an older brute is. The previous owner took out the 12/24 switch and "hardwired it into 24v" currently it appears the solid red wire and orange wire are connected and a red with white swirl wire is disconnected. I would love to understand how to connect it in a 12 V fashion and if i use it in 24V do i need to connect the black and two red wires going to the plug in 12/24 fashion (ie: one red wire to battery 1 12v potential and wire #2 red to battery 2 12v potential) or should both red wires be run off the 24v potential off the positive of battery two? Sorry if it is hard to understand i want to say the motor is an early 80's im assuming they use pretty standard color codes throughout the years.
    I have a picture of the foot pedal taken apart but am having trouble posting it through my phone.
  2. #2
    Default Re: Need internal wiring help with old 12/24 brute
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    What is the model/serial numbers?
  5. #5
    Quote Originally Posted by kimcrwbr1 View Post
    That diagram does help red and white wire is my 12v wire. Thank you!
  6. #6
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    I dont think it really matters all the two way switch does is switch batteries. If you want to switch between 12 and 24 volt just install the two way switch it only has one wire going to the speed switch I believe that is the orange wire. is yours a four or five speed?
  7. #7
    It is a 5 speed without the switch installed if i connect the red and white wire instead of the red wire it should be the same as switching from 24v to 12v using the switch? Almost like a manual switch haha, are the switches easy to get these days? Ive looked for what model it is im not too sure i have the book but its for a couple different type motor guides copy right on the book says 1987
  8. #8
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    what two types?
  9. #9
    what two types?
    I think it could be the 720 model it also mentions the 600 series and the 550, but i think those are hand controlled.
Similar Threads
  1. Internal Engine Wiring Harness
    By mikegpalmer in forum Mercury Mariner Outboard Forum
    Last Post: 10-10-2013, 07:10 PM
  2. INTERNAL Wiring Harness
    By Dan Wasiejko in forum Mercury Mariner Outboard Archive
    Last Post: 10-08-2008, 04:09 PM
  3. Internal wiring harness on 1977 evinrude 35
    By wesley bertoldi in forum Johnson Evinrude Outboard Archive
    Last Post: 02-12-2007, 07:50 AM
  4. Johnson 55 approx 19745 power tilt internal wiring
    By kiwireg in forum Johnson Evinrude Outboard Archive
    Last Post: 12-23-2005, 11:01 PM
  5. 83 Evinrude 25hp Internal Wiring Harness
    By steve b in forum Johnson Evinrude Outboard Archive
    Last Post: 07-01-2003, 04:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
