For three winters down South we usedour brand new MFS6C on our sailboat dinghy and it worked fine. Eachyear we stored the motor with all fuel drained, including carb andfuel lines and internal tank, laid down on the tiller side, butwithout fogging the cylinder. No major issues those years.
Last year we flew down the to sailboat,in Grenada, and the outboard pulled very hard and we never got itstarted. The local mechanic also failed in 5 hours of effort. Thespark seemed good – also tried changing the plug. The are no partsin Grenada, and he has no tools. With his thumb on the plug holewhile I pulled – he thinks the compression is bad, and maybe therings have gotten in a bad way. He got a single ”pop” afteradding some heavy oil in the plug hole (he thinks it helps get one ortwo good compressions). Nothing else. He didn't have any startingfluid. Still harder to pull than normal after all this. This puzzlesme...
We gave up, stored the engine downbelow, and bought a new 3.5 HP 2-stroke, which worked great on ourdinghy all winter (although a little weaker than desired).
We're getting ready to fly back to theboat, in Puerto Rico now, and I'm looking for advice:
1 – What could be wrong with thismotor and what should we try next?
2 – What tools or parts should buyno and take down with us? Even in Puerto Rico parts may be hard toget, and although airmail packages to Puerto Rico are much cheaperthan Grenada I still lean towards having what I need and not waitingor parts...
I have bought a compression gaugeand own and have studied the Service Manual.
Should I buy the carb kit($34)? The Power Unit Gasket Set($45)? New Piston Rings ($20)?
We're pretty handy and have tools onboard. We do have one luxury of time – we can work on this motorwhile using the 3.5 HP on the dinghy. The issue is that once wecruise away from Puerto Rico to other islands parts are completelyunavailable.
Thanks for any advice! I'm seems ashame for this motor to be a complete loss...
