Results 1 to 2 of 2
  1. #1
    Default Dropped plastic in heat exchanger of Yanmar 2GM20F. What to do?
    When checking the coolant of my Yanmar 2GM20f diesel, after removing the pressure cap, the small 2 inch tip of the cheap plastic antifreeze tester fell off into the reservoir and I can't fish it out. Any suggestions on how to get it out. Would it hurt anything to run the engine with it in there? Thanks.
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,747
    Default Re: Dropped plastic in heat exchanger of Yanmar 2GM20F. What to do?
    Try siphoning all fluid out of heat exchanger or draining exchanger to get a visual, Then you might reach plastic piece with a pair of mechanical fingers
Similar Threads
  1. Yanmar 2GM20F stalling problem.
    By prjacobs in forum Yanmar
    Last Post: 09-30-2014, 12:02 PM
  2. 2006 F 60 dropped plastic down dipstick hole
    By Spoolmak in forum Yamaha Outboard Forum
    Last Post: 04-16-2013, 10:20 AM
  3. Yanmar 2GM20F Alarm failure 1994
    By dave14 in forum Yanmar
    Last Post: 12-28-2010, 04:33 AM
  4. Yanmar 2GM20F Compression Check
    By barnaclebobby in forum Yanmar
    Last Post: 08-14-2010, 09:14 PM
  5. Yanmar 2GM20F kill switch
    By Sloopguy in forum Yanmar
    Last Post: 09-21-2008, 02:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
