Results 1 to 16 of 16
  1. #1
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    Default 1982 Chrysler Sea King 15hp WOT issue
    I have a 1982 Chrysler Sea King 15hp. Just replaced head gasket and rebuilt the carb. When I'm running WOT, it surges down. Found out today that if I pump the fuel line bulb while running wot it runs just fine, stays and doesn't surge. Is this the fuel pump? Also have noticed air bubbles in my internal fuel lines but no fuel leakage so assuming it's not an internal fuel line issue. Any help, ideas or questions would be appreciated! Thanks!!
  2. #2
    Join Date
    Jan 2015
    Location
    Hernando, Mississippi
    Posts
    190
    Default Re: 1982 Chrysler Sea King 15hp WOT issue
    It could be the fuel pump. If it is the same fuel pump I have on my 9.9 the rebuild is a breeze and the kit is not expensive at all.
  3. #3
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,945
    First check all connections from tank to fuel pump, sounds like an air leak possibility, troubleshoot first then spend $$$$ Keep us posted with results. If everything checks out,test fuel pump with gauge, Can be borrowed from auto parts store with a deposit
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,734
    Sounds like the diaphram is getting stiff real easy fix.
    http://www.marineengine.com/newparts...num=SIE18-7805
    Pull the fuel filter it is part of the inlet nipple of the pump and clean it with a fine wire brush after soaking in carb cleaner.
    http://www.marineengine.com/newparts...=MER22-F901811
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  5. #5
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    I r/r the fuel pump. In doing so, I removed the fuel filter screen as it was hardened and mostly clogged. There was a stick inside the filter. I added an inline filter to the fuel hose.
    The engine started and ran great but is now causing new problems...
    As the engine warms it now blows gas out of (what I'm assuming is) a vent on the top of the carb (a little back and to the right of the idle set screw when sitting in boat and looking at engine). Is it possible that my carb settings are bad since the carb was rebuilt and tweaked with a non functioning fuel pump? What advice can you give me for this issue?
    I'll try to post some pics of where the problem is occurring when I have time but will hopefully post a running video now.https://youtu.be/olEh3ZBYD1k
  6. #6
    Join Date
    Jan 2015
    Location
    Posts
    190
    Sounds like the float may be sticking.
  7. #7
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    Quote Originally Posted by Bullie View Post
    If I hadn't recently done a carb rebuild, I'd be more open to thinking that's right. I don't understand how the fuel pump rebuild could do drastically affect the float or carb other than to allow more fuel to enter
  8. #8
    Join Date
    Jan 2015
    Location
    Posts
    190
    I honestly don't know enough to be offering advice but I have had several of those. And, every time I have had a carb leaking from the overflow it has been because I did something wrong with the float/valve. I would guess that the increased flow from the properly functioning fuel pump would make issues with the carb settings stand out more. I am sure someone with a ton more experience than I have will come along with an answer that makes much more sense.
  9. #9
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    I appreciate your honesty. When I have time, I'm thinking I might tear apart the carb again and give her another go. We'll see... It does make sense, what you're saying
  10. #10
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,734
    Does it have a cork float? If so dry it out good after sanding it smooth. Then dunk it in a small dish full of fuel proof clear model airplane dope and let it dry good. If you put finger pressure on the float needle you may have damaged it just install a new needle and seat?
  11. #11
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    It's one of those black composite or plastic floats.. From what I've read in the repair book, it's kinda looking like the float is supposed to be almost level (although below, of course) with the bottom of the carb before the bowl is put back on. If I remember correctly, I believe the float was hanging at more of a downward angle. I may adjust that....
  12. #12
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,734
    Turn the carb upside down and the float should be level with the body. Like I sai do not put finger pressure on the float just check it with the weight of the float only. If you need to adjust it pull the float and then bend the arm and then check it again using only the weight of the float on the needle valve.
  13. #13
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    OK, thank you
  14. #14
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,734
    http://www.marineengine.com/newparts...pnum=MERF10120
    Install a new needle and seat just bend the tip of a small paperclip into a hook and pick out the old seat.
  15. #15
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    Awesome! Sure do appreciate the link for the part
  16. #16
    Join Date
    Jul 2016
    Location
    Saint Cloud, FL
    Posts
    21
    OK, tore the carb apart again. Swapped the float seat fitting (?? The copper thing the float needle inserts into). I put the old one back in, took the new one out because they're engineered differently. Kept the new needle in. Then adjusted the float.
    Seems to be running better now. I appreciate everyone's help.
    Attached are some videos of it running in a tank, one running, one running and shifting.https://youtu.be/bCc9eT2gn7Qhttps://youtu.be/FsrSxSlFvD0
Similar Threads
  1. 1984 Chrysler Sea King, 15hp. Lagging in forward gear
    By LoganB in forum Montgomery Wards Sea King
    Last Post: 07-26-2016, 07:02 AM
  2. 1982 15hp Johnson
    By Dave Sharkey in forum Johnson Evinrude Outboard Forum
    Last Post: 05-27-2014, 12:42 PM
  3. Replies: 2
    Last Post: 09-28-2010, 04:09 PM
  4. Used 15hp Chrysler Sea King Ser# Mdl #
    By johnjr001 in forum Montgomery Wards Sea King
    Last Post: 09-21-2008, 12:05 AM
  5. Mixture for a 1980bs Wards Sea King Chrysler 15hp motor
    By pete in forum Outboard motors archive 2000-2004
    Last Post: 04-30-2002, 10:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
