Click for Crusader parts and manuals!
Results 1 to 6 of 6
Thread: Repower options
  1. #1
    Default Repower options
    I have a 1987 Tiara open with twin 454 with 2600+ hours each. What would be a suitable replacement?
  2. #2
    Join Date
    Dec 2006
    Location
    Greenfield Me. USA
    Posts
    6,043
    Default Re: Repower options
    Ayuh,.... A couple of 454 long blocks,...
  3. #3
    Join Date
    Mar 2010
    Location
    Middletown, Delaware,
    Posts
    121
    You looking to stay with gas? If so, I would rebuild what you have in the boat now. I have done that a few times with my boat. Pull the engines, tear them down, put in new parts and away you go. I liked keeping my blocks and heads since I knew what I had.
  4. #4
    Join Date
    May 2009
    Location
    Brooklyn, NY, USA
    Posts
    192
    You could go brand new. I replaced my twin 454 340 hp with new Crusader 7.2 MPI. Performance is about the same. Fuel consumption is a bit less. Took a lot of weight out of the boat. Everything is new with a warranty.When you factor in the cost of new parts that you hang on those long blocks the high initial cost of all new looks pretty good. I purchased my engines with rebuilt velvet drive trans mounted & plumbed by the dealer. I did the install myself. I had the room & they were truly "drop in". I had to take an inch of pitch out of the props to get the RPMs up. This was in 2007 and very little has been spent on repairs since then. After almost 10 years I am very happy with the new engines.
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,285
    as noted above, lots of options....I'd say your expectations, preferences, and the thickness of your wallet will be the biggest driving factors....as with most things, there are pros and cons with any options...so you need to figure which option is best for you...the range is laid out in the previous posts...
  6. #6
    Join Date
    May 2009
    Location
    Brooklyn, NY, USA
    Posts
    192
    One more thought. When your done with your repower,contact your insurance carrier. You will have invested considerable $ in your 30 year old boat. You certainly don't want to get "book value"if something bad happens. Try to get an "agreed value" policy. Im glad I did. It worked out very well for me after Sandy.
Similar Threads
  1. So Many Options
    By willow in forum Crusader Marine Engine Forum
    Last Post: 06-15-2015, 05:02 PM
  2. Repower 290DPA Engine options
    By hookipa in forum Volvo Penta Diesel
    Last Post: 12-27-2009, 02:34 PM
  3. Options for a 454 cid
    By fred70 in forum Crusader Marine Archive
    Last Post: 02-15-2009, 07:21 PM
  4. BaylinerAQ270 Repower options
    By jamie392 in forum Volvo Penta Gas Archive
    Last Post: 07-29-2008, 07:28 PM
  5. Bertram 28 what are diesel repower options
    By Robert Brauns in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 01-11-2007, 03:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
