I replaced the water pump on my 1998 johnson 115. J115tsxecm. Pump was 2 years old and in decent shape. I run in salt water so figured it would be good measure to replace it. Motor never overheated before I installed new pump. Motor now overheats with muffs on it in driveway. So I figured I installed impeller or something in water pump wrong. I used all new parts in water pump rebuild. So 4-5 attempts to reinstall water pump engine still overheats. I followed manual for my model of engine to make sure all gaskets are in right place and impeller fins are facing right direction and used gasket maker. Tell tail is flowing fine. Removed thermostat and all though it is corroded it opens up at right temp. I'm in the process of installing new thermostats, gaskets and springs to rule that out. Water from tell tail is getting extremely hot and so is both cylinder heads.
Unless water pump is installed wrong which I really hope not as I followed schematic for specific engine model only other thing I can think of is something may have got lodged in water tube slowing down flow of water.
Do do I have to lift motor to install new water tube. Or can I just pull old one out put new water tube back in?
is there anything I'm missing here? And other possible reasons why after I installed new water pump engine overheats?
i feel like a fool cause everything was fine before I installed new water pump. I try to do everything myself following Manuel so I learn as I go. Hope I can fix this one.
