RicardoMarine
Gold Medal Contributor
Rick, I just re-read you thread from the beginning.
You mentioned "rebuilt" engine. Can you be very specific as to which piston profile was used, and as to which cylinder head combustion chamber volume was used?
This must be correct for a Marine Cruiser engine.
Depending on the piston profile, Quench or NO Quench, and combustion chamber volume, 32* @ 2,500 rpm can be a recipe for Marine Load Detonation.
In post #20 you mention seeing an ignition advance of 32*.
When adjusting the ignition advance, be absolutely pro-active with regard to looking at the progressive advance curve and the TA (total advance) and at which RPM it is "full in". And yes.... even when setting a TB system. Don't leave anything to question! Those who Foo Foo the importance of proper ignition advance do not fully understand this!!!!!
Also, TA numbers are absolutely worthless without an associated RPM.
In other words...... if you read that your TA should be XX degrees, that info is incomplete.
You want to see a TA of XX* @ X,XXX RPM.
I would suggest that you verify #1 TDC and make sure that it is accurate. The PPS and degree wheel is the most accurate means of doing this!
Then mark off your harmonic balancer (in increments of 5*) up to approx 35* BTDC.
Now when you strobe your timing marks, you will set BASE advance at idle speed.
Now increase RPM as you watch the advance.
Make yourself a paper graph showing the Advance at each RPM increment up to the Full In RPM.
You will be looking for a rather linear curve up to the point of no further advance.
In post #20, you also mentioned setting your valves.
We do not set/adjust valves...... we adjust the rocker arm nuts as to set the cam follower plunger depth to spec.
I would suggest that if you question your procedure, that you go back through these using the 8 stop method.
Start at #1 TDC on the compression stroke.
Adjust the plunger depth on both the intake and exhaust. (follow the OEM specs)
Now rotate the crankshaft 90* and adjust #8 cylinder.
Repeat the process right on down the firing order until you come back to #1.
In post #23, you asked: "rather confused as to why she idles so much faster at 30 BTDC... any ideas on that?"
At BASE RPM, you should NOT being seeing 30*. You should be seeing BASE advance ONLY.
As Jack suggests, your ignition system provides a progressive advance as RPM increases.
Rick, your engine specs will provide a WOT RPM. This is a Test RPM ONLY.
With all else being correct (hull bottom clean, engine in full tune, gear reduction being correct for the engine, propeller pitch being correct) your engine must be able to reach WOT RPM.
If it does not, you will risk over-burdening it at ANY RPM!
Use the P of E from here on out.
Good luck to you.
Good luck to you.
