Results 1 to 2 of 2
  1. #1
    Default crank case blowing oil
    When starting my older Yanmar 3GM30F the dip stick and oil shoots out from dip stick hole. Engine runs fine otherwise. Any ideas as to what could cause this? Thanks
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,908
    Default Re: crank case blowing oil
    Pressure building inside of crankcase, Is engine crankcase vented properly, Is vent clogged
Similar Threads
  1. Crank Case Breather... TAMD 41A or 40A both the same
    By bobt in forum Volvo Penta Diesel
    Last Post: 07-13-2012, 08:42 PM
  2. Someone please help, broken crank case!!
    By Graeme Gibson in forum Johnson Evinrude Outboard Forum
    Last Post: 06-16-2011, 05:27 AM
  3. 115 HP Evinrude crank case gone
    By buggle in forum Johnson Evinrude Outboard Archive
    Last Post: 06-19-2009, 04:51 PM
  4. Water in crank case
    By 47garwood in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 01-09-2008, 06:11 PM
  5. Evinrude Crank Case Pressure
    By Gary G in forum Johnson Evinrude Outboard Archive
    Last Post: 01-25-2004, 03:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
