Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 7 of 7
  1. #1
    Default help with a suzuki dt150 please
    I got a 1988 Suzuki dt150 that I have put on a pontoon and I'm having a few electrical problems. first I cant get the tach to work. anybody know which wire coming out of the motor is for the tach? also it doesn't seem to be charging , does anybody know how and what to check to see if its charging properly? any info would be much appreciated. thx, chris
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,996
    Default Re: help with a suzuki dt150 please
    Most tachs. run of the rectifier/regulator which also charge the battery, Place a voltmeter on battery posts,take reading,start engine,reading should be higher14.5 Non running reading should be 12.6
  3. #3
    I downloaded a manual and found which wire is the tach wire and hooked it up to 2 different tachs and neither work. I did your test and the voltage stays the same running as not running around 12.35 volts. the manual doesn't say exactly how to check the stator or regulator/rectifier so I'm going to cross my fingers and replace the regulator/rectifier. thx for the help.
  4. #4
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,996
    Go to CDI Electronics.com for troubleshooting advice
  5. #5
    ok, got a regulator/rectifier and the fixed the charging issue but still no tach. any ideas?
  6. #6
    gray tach will not work if some one unhookd to lights
  7. #7
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    133
Similar Threads
  1. 1986 suzuki dt150
    By kenard in forum Suzuki Outboard Archive
    Last Post: 12-21-2008, 11:24 AM
  2. 1988 Suzuki DT150 issue
    By boatmadmaniac in forum Suzuki Outboard Archive
    Last Post: 12-01-2008, 12:11 PM
  3. Suzuki dt150
    By richard desroches in forum Suzuki Outboard Archive
    Last Post: 10-22-2008, 07:49 PM
  4. 2003 Suzuki DT150 RPM max
    By DT150 in forum Suzuki Outboard Archive
    Last Post: 07-02-2008, 01:43 AM
  5. Need help 1996 suzuki DT150 not firing
    By devildog_1391 in forum Suzuki Outboard Archive
    Last Post: 06-11-2008, 04:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
