Trying to get a positive ID on my outdrive. Unfortunately the tag near the helmet is unreadable.
If this drive was not tagged "Chrysler", it may have been tagged "Eaton".
In either event, it is a Volvo Penta AQ series drive.
I found an ID chart with dozens of Volvo outdrive drawings. The AQ200, AQ250 and AQ270 outdrives look exactly the same to my eye.
The AQXXX refers to the Engine model, and will typically be followed by the drive model number.
For example: the AQ200B (5.0L GM SBC w/ 2 brl carburetor) used the 280 shield and 280 drive.
This would have been shown as: AQ200B/280.
See more Volvo Penta info here http://www.marinepartseurope.com/en/volvo-penta-schematics-MarineGasolineEngines.aspx
Only difference I saw was gear ratios.
Most all AQ series stern drives were available in different gear reductions. For example: 2.15:1, 1.89:1 and 1.61:1.
How can I ID my outdrive to buy the right service manual? I am assuming that these are the original outdrive and engine but after 45 years I cannot say for sure. Also the AQ200
If you are refering to the 200 drive, I can assure you that this is NOT a 200 drive.
and AQ250 drawings have a note saying "electro mechanical tilt". I read somewhere that there is not a trim function and tilt is used for lifting the outdrive away from the road on the trailer.
That is correct! This is a "Lift Out" device ONLY!
Further the outdrive cannot/should not be operated in the tilt up position.
It can be reversed at low idle RPM only..... but use caution.
So here are 5 images of my sterndrive. I included the image of the prop after reading that earlier sterndrive props were removed by bending the tabs away from the cone before unscrewing it. Mine has tabs. Did your 270 have trim and tilt or just tilt?
The SS locking tab washer was used for quite a few models, and only for the short hub propellers.
