My 2002 Mercury 40hp /2 stroke / 2 cylinder that runs fantastic
and has compression of 125 in both cylinders. But , this summer it has a constant klunking noise while it's running at idle speed in forward or reverse. It's normal and super guiet when I do one of three things. #1. Put it in neutral. (Gone)
#2. Take prop off. Or #3. Give it roughly 200 additional RPM's
then its gone.
***The only thing I found is if the motor is OFF....in nuetral I can spin "by hand" the propeller left or right and it turns super smooth and gears clicking.
If I put the motor in forward, I can not turn the prop counter- clockwise but I can turn it clockwise smoothly with a rhythmic clicking.
NOW....if I put the motor in reverse, I cannot turn the prop
clockwise....(but I can't turn it counter-clockwise either and get
that rhythmic clicking.)
When the motor is running in a barrel....it goes into reverse just fine...but there is still the klunking sound running in forward and reverse.
The prop should spin by hand counter-clockwise by hand with a slight clicking,...correct?
i drained the lower unit oil...and it's super clean with no water and there is it any metal shavings on the drain plug.
Any ideas if the 3 things that make the klunking go away could be related to a reverse issue here??
then its gone.
