Results 1 to 5 of 5
  1. #1
    Default GM 3.0 to stright marine drive
    Have a small plywood inboard (Correct Craft, Atom Skier) powered by a Gray marine 70 hp flathead 4, would like to increase power without butchering the hull. Was thinking a 3.0 Gm based 4 cylinder of 120-140 hp would give me a nice power increase. I know theses engines are used in many IO applications but was wondering if they can be adopted to straight inboard drive using a velvet drive or whatever.
    Any thoughts or opinions, using other choices,would be appreciated. Thanks in advance
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,310
    Default Re: GM 3.0 to stright marine drive
    should work...assuming you have enough space....
    Just make sure the shaft and strut are adequately sized and are in good condition....figure a new prop (or repitch, if you are lucky) as well....I'd also change the bearing and stuffing box hoses, as applicable, while its apart.
  3. #3
    Not sure what I need to connect engine to a velvet drive trans. Does the 3.0 share the same bellhousing as, say, a chev v8?
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,310
    pretty sure they all have the same bolt pattern - block to bell housing....
    you'll need a solid flywheel and a damper plate to bolt to it, with the splines to match the velvet drive's input shaft.
  5. #5
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,541
    Quote Originally Posted by makomark View Post
    Ayuh,.... Block to flywheel cover bolt pattern is the same, I-4 to I-6 to SBC to BBC,....
    Crankshaft bolt patterns, 'n flywheel balance does change is some instances,...
Similar Threads
  1. Replies: 8
    Last Post: 02-25-2011, 09:36 PM
  2. Marine power small block to vee drive hookup
    By partgypsy in forum Marine Power Engine Forum
    Last Post: 09-01-2010, 09:12 AM
  3. Chrysler Marine 270 drive. OIL?
    By yago in forum Crusader Marine Engine Forum
    Last Post: 05-21-2010, 10:21 AM
  4. KAD42 MARINE ENGINE DRIVE GEAR PROBLEMS
    By rainman77 in forum Volvo Penta Diesel
    Last Post: 06-22-2009, 05:20 PM
  5. Drive an Air Prop with a Marine OD
    By PaulMinnicks in forum Archive 2003-2009
    Last Post: 07-10-2002, 11:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
